I am using CY3689 DK for displaying video / image on VLC or MPC-HC player.
I have taken "https://community.cypress.com/t5/Knowledge-Base-Articles/USB2-0-Camera-Interface-Using-FX2LP-and-Lat..." example as a reference. Changed endpoint buffers in Slave FIFO implementation part of example code. But I am not seeing any display on VLC or MPC-HC player.
I am also trying to analyze Wireshark packet but not able to do so. Please help to suggest what might be wrong here.
I will attach here the Wireshark capture data for your reference.
Hi MallikaK,
I found the issue with my code.
This "/* No. of bytes device can rx in single payload-1932 */" setting is what was causing problem in transfer of data from FX2LP to VLC. I changed it to a multiple of 512 and everything started working.
Also what is the significance / difference between EP_INT_VIDEO and EP_BULK_VIDEO? I was not able to get this from code. And is this setting in the above code will provide me maximum speed or can I improve it a bit more?
Please check this.
Please help.
Please attach the complete project, if possible.
Mallika
Hi MallikaK,
Please find the attached code I am using.
I am using "https://community.cypress.com/t5/Knowledge-Base-Articles/USB2-0-Camera-Interface-Using-FX2LP-and-Lat... example code attached inside it and made changes for buffer setting and such thing.
Changes done to sample code:
1. Currently I am using EP6 for receiving data from FPGA and sending to PC.
2. I am running on External clock frequency from the start.
3. Polarity of flags and external clock is reversed right now.
4. I have used same configuration in the Slave FIFO sample code and have been able to fetch data from FPGA using USB control center.
Hi MallikaK,
Any suggestion from your side?
The interrupt transfers from the interrupt endpoint are not occurring.
From the code, it can be understood you are using EP6 for Bulk in transfer. The other endpoint, i.e. the Interrupt Endpoint is used to communicate UVC-specific status information. Although in your descriptor file you are using EP1 for INT transfer, you haven't configured EP1INCFG in slave.c file.
Kindly set EP_INT_VIDEO to 88H in the descriptor file. In the slave.c file configure EP6 for BULK transfer. Configure the other endpoints (2,4,8) as EPxCFG &= 0x7F.
Kindly check and update the results.
Mallika
Hi MallikaK,
