Hi All,
I'm having a CX3 device which is programmed to act as a UVC-CDC device(based on the sample code Cx3UvcOV5640_UVC_CDC).
The Stream is having some issue in USB 2.0 for some resolutions but it's working perfectly in USB 3.0.
Please find the observations when streaming in USB 2.0.
Resolution 640 * 180 @ 60fps is successfully streaming but the 960 *360 @15fps is having issue. Frame format used is RGB24.
When trying to stream "CB failure" occurs and CX3 tries to restart the stream repeatedly.
If the restart sequence is commented I get the following debug prints. Adequate data is not received in this case, the actual size should be ( 960 * 360 *3 = 1036800 B )
Prod = 20 Cons = 15 Prtl_Sz = 5952 Frm_Cnt = 28 Frm_Sz = 742272 B
Prod = 20 Cons = 15 Prtl_Sz = 5952 Frm_Cnt = 29 Frm_Sz = 742272 B
Prod = 20 Cons = 15 Prtl_Sz = 5952 Frm_Cnt = 30 Frm_Sz = 742272 B
The DMA configuration for CY_U3P_DMA_TYPE_MANUAL_MANY_TO_ONE is
dmaCfg.size = CX3_UVC_STREAM_BUF_SIZE; // 0x8FD0 + 12 + 4
dmaCfg.count = CX3_UVC_STREAM_BUF_COUNT; // 3
dmaCfg.validSckCount = CX3_UVC_SOCKET_COUNT; // 2
the endpoint configuration is
endPointConfig.pcktSize = CX3_EP_BULK_HIGH_SPEED_PKT_SIZE; // 0x200
endPointConfig.burstLen = CX3_EP_BULK_HIGH_SPEED_BURST_LEN; // 1
Could you please help me on this.
Ajay
The issue was that the sensor was sending data at a high data rate( Data in a quick burst)
So this was above the capability of USB 2.0 to capture.
Now sensor is updated so as to send 720 * 360 @ 15fps at an evenly distributed range.
With this configuration the streaming is working successfully.
Thanks for the support.
Ajay
Please confirm whether you are receiving 960 * 360 *3 = 1036800 B in debug prints in USB 3.0 case.
Please probe HSYNC_test, VSYNC_test and PCLK pins in both USB 3.0 and USB 2.0 case for 960x360x3 bytes and find the difference between them.
In USB 3.0 i'm receiving the 1036800 B print.
Also probing the V sync test signal for 960 * 360 @15 fps gives 15Hz for both USB 3.0 and 2.0.
Is the VSYNC_active and HSYNC_active duration are same in USB 3.0 and USB 2.0?
Yes.
For 15FPs the V sync is 15hz and the H sync is 27Khz in both USB 3.0 and USB 2.0
Please share the .C file and required header files for review.
The .c file is fine.
It looks like the host is not able to stream the 960 * 360 * 3 at 15 fps. Hence, you are seeing commit buffer failurs. Can you please reduce the frame size to 10 (in USB 2.0 for debugging) and check?
I tried making it to 5 fps and the same issue persists.
In one or two prints i got the full frame size 1036800 B
Could you share a CX3 project that would ideally stream this data.
960 * 360 @15fps and format RGB24
Ajay
