TeMa_2997106
Level 6
Level 6
10 likes received 10 solutions authored 250 replies posted
The power-on sequence is described in the data sheet.
(Within 10ms between VDD and VDDIO1)
What failure mode will occur if this specification is violated?
Tetsuo
YiZ_31
Hi Tetsuo-san,
The most common scenario is that the device could not enumerate correctly after reset.
Eddie
YiZ_31
Hi Tetsuo-san,
Eddie
Eddie-san,
Thank you for your answer.
I understand that it will not suffer serious damage such as device destruction. Is it correct?
Tetsuo
YiZ_31
Hi Tetso-san,
No, it will not cause device destruction.
Eddie
Eddie-san,
Thank you very much.
I understand.
Tetsuo
