KyUn_4602541
10 replies posted 5 replies posted First like received
We are designing a board that we want to use with as many Android phones as possible.  What would be the most generic, widely support USB 2.0 chipset that we can use?
Alot
MallikaK_22
250 solutions authored 500 replies posted 250 replies posted
Please refer to USB Serial Bridge Controllers (https://community.cypress.com/t5/Knowledge-Base-Articles/Key-Features-of-the-Cypress-USB-Serial-Brid...
They are compatible with Android.
You can install the USB-Serial Android SDK from https://www.cypress.com/documentation/software-and-drivers/usb-serial-software-development-kit . Please go through the README file and the start.chm document in the docs folder for more details on the SDK.
Mallika
MallikaK_22
Mallika
KyUn_4602541
Thanks.  Can you tell me if there is chipset that will do a faster rate >45Mbps instead of SPI?  Is there a general list of chipsets that are supported by Android?
MallikaK_22
Please give a detailed explanation of your application and what you want to achieve?
Mallika
