I am working on Cy7C680-13A 56-pin cypress usb controller. I need to use the device controller as slave FIFO to receive data from the external master device (my external master device is a cmos image sensor). The USB device controller should be configured to work in asynchronous mode.
Is there any application note and demo code which illustrates the asynchronous slave FIFO cofiguration mode working of the controller ?
Thank You
Here you go http://www.cypress.com/?rID=45850.
Gayathri
