 I read 153600-byte data from external FIFO using GPIF FIFO read mode.
And now I want to modify my 76800-77024 (1024 bytes) data into 0xFF.
The problem is that the new data will fresh EPxFIFOBUF. And I can't pause the GPIF to have enough time to process my old data.
Is it possible to finish this task?
 When you say I cant pause GPIF, is it an application requirement? Why can't you pause GPIF? Are you dealing with Streaming application? Please give more information about your requirement.
