USB low-full-high speed peripherals
tayoc_1249536
10 sign-ins 5 questions asked 5 sign-ins
I am designing a circuit that uses the CY7C68013A as a USB peripheral controller.
I have a  question below.
1.  What is the minimum and maximum time from when the reset is released until the D+ pull-up is enabled?
According to "4.2 Enabling Pull-up on D+" in the PDF file at the URL below, it says "the FX2LP enables the pull-up on the D+ once the RESET is deasserted".
What is the minimum and maximum time from reset release until D+ pull-up is enabled?
https://www.cypress.com/file/142746/download
Regards.
MallikaK_22
Moderator 250 solutions authored 500 replies posted 250 replies posted
Apologies for the delay in my response.
Please refer to section 7.1.7.3, Fig 7-29 in the USB 2.0 specification.
The device should pull up the D+ line within 100ms when VBUS reaches up to 4.01V.
Mallika
MallikaK_22
Apologies for the delay in response.
Please check Table 5, Page 9 in the FX2LP datasheet: https://www.cypress.com/file/138911/download
tayoc_1249536
Thank you for reply.
Please let me know the minimum and maximum time of the ? Part of the attached image.
Regards.
MallikaK_22
Mallika
tayoc_1249536
I understand that the device should pull up the D+ line within 100ms when VBUS reaches up to 4.01V.
Please let me know  the FX2LP's minimum and maximum time from FX2LP reset release until D+ pull-up is enabled?
Regards.
tayoc_1249536
When you have time, I would appreciate more information on the progress of the question.
Regards.
MallikaK_22
FX2LP does follow the USB specification, so the maximum time from the FX2LP reset release is 100ms. The minimum time is 5ms.
Mallika
