Hi  Сергей Полозов,
FX2LP has to be used in GPIF mode to get the data from the ADC.
Please refer the application notes
http://www.cypress.com/?rID=12937
http://www.cypress.com/?rID=45850
www.cypress.com/?rID=39392
I assume that you are C++ builder (Visual studio) correct me if I am wrong.You have to use cyusb.dll and cyusb.h.Please download and install Cy3684 DVK http://www.cypress.com/?rID=14321. You can get the library files in the path C:\Cypress\Cypress Suite USB 3.4.7
Vikas.
I am sorry, the name of the file is cyapi.h. You can find it in the path C:\Cypress\Cypress Suite USB 3.4.7\CyAPI\inc
Vikas.
 Thanks, but
" need an example program for CY7C68013A-56pin for the bridge usb - FIFO with a sampling frequency of 48MHz " ....
Hi ,
The application note and project in the link http://www.cypress.com/?rID=39392 are for 48MHz interface clock only. (Though it is for 128 pin ). You can edit the project as per your requirement.
Vikas.
