hi
i have implemented the 16 bit slave fifo for the FPGA to fx3 to GUI data transfer. For the conatsnt data (Such as 0x0055), i am getting corrected data. But for incremental data (such as 0x0000, 0x0001, 0x0002), i am not able get the propoer data sequence. I am getting the sequences like 0x0000, 0x0001, 0x0001, 0x0004, 0x0004, etc..
How can i get the exact data sequance.??
i am changing the data sequence on the falling edge of the PCLK.
Thank you.
- I hope FPGA is providing the clock to FX3(What is the frequency). Please confirm.
- Please attach the FPGA write timing diagram(showing data with respect to control signals) and also your FX3 state machine.
Hemanth
FPGA is prviding clock to FX3 of 100 MHz fequency. Simulated data are also changing as per below diagram.
Please attach your GPIF state machine.
Hemanth
I have taken same GPIF state machine as given in slave FIFO example. i am getting the data sequences as hown in below Fig. you can see that after two successfull consecutive data, next two are missing and further repeats same.
Please observe the GPIF interface on an oscilloscope. Verify whether the timing diagram given in Fig.12 of fx3 datasheet is satisfied.
Hemanth
