USB hosts hubs transceivers Forum Discussions
We have an application that requires 2 UVC cameras, so we layout 2 child-board with cyusb3065 & sony sensor (USB3 HUB on main-board),  but we get some problem in test :
1. one cam can work, but 2 cam will stop working after 2~5 seconds.
2. if I add one USB3 hub between device & PC, then 2 cam can work properly.
Is there any idea for this problem? or could I solve this with some error-catch code?
YangyangC_06
In case 1, how do you connect two sensors, CX3 and PC in your system?
YangyangC_06
