Is it a problem if the absolute maximum rating of input voltage -0.5V is violated even for a short time?
The undershoot of the input signal of a pin is large, and the time is about 1 ns, which is about -0.8V. I would like to know if measures are needed.
Tetsuo
Hi Tetsuo,
If you read Page 16 in the HX2VL datasheet, it's mentioned that "Exceeding maximum ratings may impair the useful life of the device".
Mallika
Hi Tetsuo,
Mallika
