USB hosts hubs transceivers Forum Discussions
ShPe_4630301
First like given
I'm implementing a Data transfer Interface to bypass the proccessed data from a FPGA to the PC. I need high datarate and Power supply for FPGA and other parts connecting to the FPGA. As follows:
Data Transfer to PC: Sample Data -> FPGA -> USB -> PC
Flashing programs to the boards: PC -> USB -> FPGA/Other MCU
Power Supply: PC -> USB -> FPGA/Other Hardware
Any Ideas, recommendation or suggestion, which IC has to be Chosen?
Sananya_14
Please let us know the data rate you require? You could check if FX3, our USB 3.0 controller, would be a suitable part for data transfer and firmware update to FPGA. Please find the relevant App Notes- AN65974 and AN84868.
Please also explain your power supply requirement for FPGA?
Sananya
Sananya_14
Sananya
Thank you for your response. My candidates are, FX3 and FX3S. I want to use just one USB Type-C to comminucate with pc and get the power from pc. I just created a coarse schematic of the implementation and added to this post. Power has to be standard as usb type-c power delivery, 7,5 W.
Thank you in advance!
Best Regards
Thank you for the update. Please check this KBA for your reference. For the Type-C controller you can check CCG2, CCG3PA or BCR as per requirement.
Sananya
Thank you so much for your response. I read the documents you've sent to me and if I have still questions, I'll keep in touch with you.
Have a nice day.
Best Regards
M. Peiro
