I successfully ran the PSOC 5LP example project: USBFS_Bulk_Wraparound and communicated with the PSOC over USB bus using my PC with Windows 7.
But now I need to install a driver for this project onto my embedded computer running Windows Compact Embedded 2013 operating system. When I run CySuiteUSB_3_4_7_B204.exe on the embedded computer I get a message that it is not a valid Windows Compact Embedded application.
Is there a driver for this project for Windows CE? -Aaron
CySuiteUSB_3_4_7_B204.exe is a windows application, it is suppose to unzip and install the corresponding drivers depending on your OS. Cypress CyUSB3.sys driver is expected to work on Embedded OS as well. Kindly download the latest drivers directly from: http://www.cypress.com/knowledge-base-article/drivers-ez-usb-fx1-fx2lp-and-fx3-kba94413
Nishant, thank you for that.
