Trace length of upstream and downstream port of HX3
KyleLin
Distributor - Weikeng(GC)
First solution authored 50 sign-ins First like received
Per HX3 design guide, we learn PCB trace length must under 11" on downstream port.
How about the maximum PCB trace length of upstream port ?
Kyle
Ajeethkumar_P
50 likes received 500 replies posted 100 solutions authored
Hi Kyle,
Thanks for posting in the Infineon Developer community!
HX3 SS lines(irrespective of Upstream or Downstream) are characterized for a trace length of up to 11 inches.
Ajeeth
Ajeethkumar_P
Hi Kyle,
Ajeeth
KyleLin
Hi Ajeeth,
How about the maximum PCB trace length of USB2(D+/D-)?
Kyle
Hi Kyle,
The same trace length is applicable for HS(D+/D-) lines as well for HX3.
Ajeeth
KyleLin
Thanks Ajeeth.
KyleLin
Hi Ajeeth,
One more question, what is the maximum HS(D+/D-) trace length of HX3 if we don't consider SS. For example, we connect the one of DS port to connector with HS only signals, without SS signals.
Kyle
Hi Kyle,
The Trace length for HX3 HS lines should be within 11 inches whether you use SS lines or not.
Ajeeth
