I am using CYUSB3328-88LTXC hub to connect with Jetson nano as HOST and and on the peripheral side it is Intel Real sense.
In default mode of operation, we are able to detect peripheral devices as USB2.0 but unable to detect USB3.0 peripherals.
I am attaching snapshots of schematic part. please help me to resolve this issue
USB Superspeed Peripherals
Thanks for the update. Please try the hardware change suggested in the previous response since the issue is only with the 3.0 lines after the multiplexer on DS1 and not the hub upstream port. You could check the datasheet application diagrams or with the manufacturer for recommended decoupling capacitors on the multiplexer inputs.
Sananya
-Please try putting 0.1uF decoupling capacitors on the TX, RX lines on the multiplexer input side.
-Please let us know if the USB 3.0 part of the hub is enumerating on the host.
-Is this issue seen on any other DS ports of the hub other than DS1?
Sananya
Hi Sanaya,
USB.3.0 is enumerating on the host.
We are using only one port for USB3.0
Sananya
