The data sheet of HX2VL has the following description.
The internal reset is initiated, when there is an unstable power event for silicon’s internal core power (3.3 V ± 10%). Internal reset is released 2.7 µs ± 1.2% after supply reaches power good voltage (2.5V to 2.8V).
After starting up to the normal voltage (3.3V), how many volts does the voltage droop before the POR sequence starts again? Doesn't POR start until it droops to 2.5V?
HX2LP has no description in the datasheet, but is it the same rule?
Tetsuo
USB Hosts Hubs Transceivers
Hi @TeMa_2997106 -san,
Sorry for late to reply back to your question on this topic.
I recommend you to add supervisor IC if you want to make sure reset timing after abnormal condition like brownout and overload for HX2LP. Unfortunately, Vbus monitoring function could not be used for supervising of reset pins.
@TeMa_2997106 -san,
Thanks for posting your questions on this community.
I'm checking that to expert and I'll get back to you soon.
I understood what you want to know is recommended HX2LP's POR process, Is this understanding correct?
Takashi-san,
I use both HX2VL and HX2LP. Therefore, I would like to know the specs of both.
Tetsuo
@TeMa_2997106 -san,
Thanks for your supplementary comments.
Regarding POR, HX2VL has internal POR circuit and works it as you mentioned above.
For HX2LP, it does NOT have internal POR circuit so external and need to apply reset signal externally if Vcc get out of range. This is a background why LP has independent Vbus monitoring pin.
Takashi-san,
Could you tell me the specific schematic configuration of HX2LP?
I would like to reset the power supply without external control (with only passive components).
Tetsuo
