PD hub concept recommend
role_1685151
25 sign-ins First like given 10 sign-ins
I'm looking for appropriate solution like Type C PD hub.
Currently, spec is below.
-Charging : Type C charging / Type A charging(BC1.2 CDP) from TA(Type C UFP port)
-USB data : USB 2.0 communication between Type C host and Type A device
I had reviewed what is appropriate solution for.
The similar solution is CCG3 CTD solution. but I think it's heavy a little.
Among PD hubs, HX3C is supporting 2 DRP role. but PD Port2 was using DFP port on HX3C Dock reference design.
If you know that there is appreciate solution. let me know and guide.
Regards.
Robert
Hi Robert,
My understanding is you would like to have DS port as a Type-C receptacle for sink i.e. charging from external adapter and have US port as a Type-C plug for source to the host i.e a dongle design. In that case, you could refer to the CCG3 Charge-Through-Dongle solution as you had mentioned with modified design on the HX3 DS ports. This would allow the same firmware to be used except for some configuration change on HX3 to disable the unused ports.
The HX3C Dongle part could also be used but please note that we have no reference design for that application.
Sananya
Sananya_14
-For the block diagram, could you please clarify if you require DRP role for both Type-C ports?
-Please note that HX3C based dock solution is not recommended for new designs. You could refer to the CCG4 Dock solution or HX3PD, although H3XPD has a lot many features than required so it might be an overkill.
Please also refer to the KBA​ for comparison between the hub solutions.
Sananya
Hi Sananya.
No. I think no need DRP role to Type C ports. because Type C plug will connect to host device. and Type C receptacle will be used to charging sink role.
Sorry. I know HX3PD is not support UFP role for charging sink port.
CCG4 Dock design isn't also supporting UFP charging sink port.
https://www.cypress.com/documentation/reference-designs/ez-pd-ccg4-usb-type-c-monitordock-solution
Robert
Hi Robert,
Sananya
