Dec 16, 2022
07:42 AM
Dec 16, 2022
07:42 AM
After powering up HX2VL, sometimes OSC stops oscillating even though reset has not been applied. Can a device actively stop OSC? If so, what are the factors?
I think the internal logic is not working at all because the OSC is stuck. Is this correct?
Tetsuo
Labels
USB Hosts Hubs Transceivers
09:48 PM
Dec 18, 2022
09:48 PM
>> Could you please let us know if you are using a custom board or our DVK?
>> Is the behaviour afterwards normal or any abnormalities are seen?
>> Are you using in bus-power or self-power?
Mallika
Dec 26, 2022
06:13 AM
Dec 26, 2022
06:13 AM
Mallika-san,
It is a custom board.
Power mode is self-powered mode. Power is supplied from DCDC on the board. HX2VL is always ON when the system is ON.
HX2VL is working normally.
Tetsuo
