I am using CY7C65213-28PVXI directly replacing FTDI# FT232RL but not able to work it,will you please suggest that whether i can directly use the ic or i need to do some  changes in the circuit.
YiZ_31
CY7C65213 USB-UART LP Bridge Controller is pin-to-pin compatible with the FTDI FT232R.
Please refer to the following link for relating information:
Replacing FT232R with CY7C65213 USB-UART LP Bridge Controller - KBA85921
However FT232RL is a 28-pin SSOP package which is different than CY7C65213. You may need to do some modification.
Eddie
YiZ_31
Eddie
I am not able to use the IC directly will you please suggest me driver and
when comparing pin of cypress IC there is difference in pin number
24,25,26.Will there is any issueif we use it directly in our circuit by
replacing ftd 232.(PFA our circuit)
Vicky Chaudhary
Executive-Engineering
<https://web.skype.com/>Landline : +91 253 2202120
Email :-vicky.chaudhary@rishabh.co.in <pallavi.mishra@rishabh.co.in>
www.rishabh.co.in <http://rishabh.co.in/index.php>
YiZ_31
Your may use the 28-pin SSOP package of CY7C6521 to replace FT232R. They are pin-to-pin compatible. Pin 24,25&26 will not affect the performance.
Regrads,
Yi
hello,
What are the driver we can use for cypress part.
Vicky Chaudhary
YiZ_31
You can find drivers in the following directory:
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\driver
Yi
Will you please help me another part as i am not able to get the data from
the datasheet regarding endurance parameter of IC.
http://giantec-semi.com/Upload/datasheet/GT24C64_DS_Adv.pdf
Vicky Chaudhary
please ignore mail as wrongly send to you.
Vicky Chaudhary
On Sun, Dec 2, 2018 at 11:24 AM Vicky Chaudhary <
