yish_4278406
How to connect DSx_OVRCURR when using pin-strap configuration for cyusb3314.I didn't see anything  in the datasheet.
thanks
Sananya_14
DSx_OVRCURR  pins should be pulled up with 10K resistors and are recommended to be connected to power switches for overcurrent detection. The pin-strap configuration only allows us to change the power control mode and polarity based on power switch requirement.
You could also refer to the App Note for more hardware guidelines.
Sananya
Sananya_14
Sananya
