We are currently working on a custom board using the HX3PD. We would like to disable the PD section of the HX3PD, tristate the VSEL_GPIO1 and VSEL_GPIO2 pins, and use PWREN_P1 and OVCUR_P1 to enable the USB power switch for the DS1 port and detect the overcurrent conditions respectively.
Can Cypress provide a binary with this functionality or a PSoC Creator project to enable building of custom images?
Thanks!
USB Hosts Hubs Transceivers
- hx3pd
Please refer to the HX3PD firmware in the Dock SDK which is based on the CY6611 EVK schematic. You could modify the PD controller project to disable PD for DS1 and set the MUX_CTRL GPIOs (which are mapped to VSEL_GPIO1 and VSEL_GPIO2 pins) to required state.
Sananya
Sananya
