As we know, the HX3 supports four DS ports and sharing the same of 5Gbps bandwidth.
Customer would like to know if connecting 4 usb devices ( ex: mass storage devices ) to DS,
each usb decive transfer data speed is 5Gbps / 4 = 1.25Gbps, correct cuz sharing 5Gbps bandwitdh.
Do you have any performance test document ?
USB Superspeed Peripherals
Hi Ivan Lee,
Thank you for posting in the Infineon Developer community!
We don't have documents regarding the HX3 performance test on the web. HX3 Performance is validated during our testing phase and is compliant with USB 3.0 5Gbps.
Theoretically, your calculation could be right to answer your question, but 5Gbps is not the effective data transfer rate. USB Host is responsible for allocating the bandwidth for every USB device connected to it. Also, there would be some class-based packet overheads as well. So, the effective data transfer rate would be lesser than 1.25Gbps when 4 MSC USB devices are connected to HX3.
Ajeeth
Hi Ivan Lee,
Ajeeth
