TeMa_2997106
Level 6
Level 6
Distributor - TED (Japan)
10 likes received 10 solutions authored 250 replies posted
What is the recommended operating range for the VBUS_DS pin of CYUSB3304-68LTXC?
BC1.2 and Apple-charging are not used in this design. In the current circuit configuration, 2.5V is applied. Is there a problem?
I think it should be connected directly to GND, but if there is no problem even if 2.5V is applied, I would like to leave it as is. This is because this design connects VBUS_DS to 2.5V.
Tetsuo
MallikaK_22
50 likes received 750 replies posted 250 solutions authored
No, it is required to connect the VBUS_DS pin to local 5V supply. We have seen issues in past where the hub does not functions properly if the pin is not connected to some other voltage levels.
Mallika
MallikaK_22
Mallika
TeMa_2997106
Level 6
Level 6
Mallika-san,
Thank you for your comment.
I would like to confirm something additional. What voltage exactly do you mean by "some other voltage levels"? Is there a provision for Vil and Vih?
Tetsuo
MallikaK_22
Hi Tetsuo,
The pin needs to be connected to 5V. If there are any other voltage levels, there appears to be an issue in the functionality.
Mallika
TeMa_2997106
Level 6
Level 6
Mallika-san,
When pulling up VBUS_DS to 5V, what is the operating voltage range? Also, when setting VBUS_DS to Low, what is the operating voltage range?
In another thread, it was stated that when connecting to 5V, the voltage range is 4.35 to 5.5 V. Is this correct? If it is correct, I also would like to know the voltage range for Low input.
https://community.infineon.com/t5/USB%E3%83%9B%E3%82%B9%E3%83%88-%E3%83%8F%E3%83%96-%E3%83%88%E3%83%...
Tetsuo
@TeMa_2997106 wrote:
Mallika-san,
In another thread, it was stated that when connecting to 5V, the voltage range is 4.35 to 5.5 V. Is this correct? If it is correct, I also would like to know the voltage range for Low input. smart whip delivery
Tetsuo
I working on a project involving the TLE9879QXA20, an integrated motor controller IC. The datasheet specifications meticulously, I found that the motor control outputs were exhibiting unexpected behavior, including sporadic signal spikes and inconsistent speed regulation. After conducting extensive testing and analysis, I discovered that the issue was stemming from a subtle interaction between the PWM frequency and the internal clock configuration.
TeMa_2997106
Level 6
Level 6
Mallika-san,
Are there any updates?
Tetsuo
MallikaK_22
When setting VBUS_DS to 5V, the data that you have obtained regarding voltage levels is correct.
When setting VBUS_DS to LOW, we'll have to get check this information internally.
Mallika
TeMa_2997106
Level 6
Level 6
Mallika-san,
Is there a Vih and Vil provision for this pin? If it is yes, what is its value? I couldn't read it from the datasheet.
Tetsuo
TeMa_2997106
Level 6
Level 6
Mallika-san,
Do you have any update on the question?
Tetsuo
MallikaK_22
Apologies for the delay from our side.
I'm trying to get this information internally and will update you as soon as possible.
Mallika
TeMa_2997106
Level 6
Level 6
Mallika-san,
Tetsuo
MallikaK_22
I'm still trying to get this information internally and will update you as soon as possible.
Mallika
TeMa_2997106
Level 6
Level 6
Mallika-san,
Thank you for your help. Please let me know if you get an update.
Tetsuo
MallikaK_22
In the datasheet, as mentioned, we either need to connect the pin to PWR (5V) or GND based on the application. For PWR, there's an operating range from 4.35V to 5.5V. For GND, it is generally connected to 0V and the char data is not available.
Mallika
TeMa_2997106
Level 6
Level 6
Mallika-san,
I understand that the voltage range that this pin recognizes as high is from 4.35V to 5V. What is the range for recognizing Low?
Tetsuo
MallikaK_22
Hi Tetsuo,
The char data is not available for LOW voltage. We'll have to do that which will take 1~2 weeks time. We have already started on it and will let you know the updates.
Mallika
MallikaK_22
Hi Tetsuo,
It is recommended to not go beyond 90mV to see proper enumeration.
Mallika
