USB hosts hubs transceivers Forum Discussions
TeMa_2997106
Level 6
10 likes received 10 solutions authored 250 replies posted
Level 6
My understanding is that when OVR is driven low, PWR automatically goes low. Is it correct?
My customer's board does not behave that. When OVR pin input low, PWR pin does not go high.
Where should I check on the board?
Tetsuo
MallikaK_22
Moderator 250 solutions authored 500 replies posted 250 replies posted
Hi Tetsuo,
OVR pin is active low. When overcurrent is detected, PWR (active low) should be disabled (HIGH).
If overcurrent is detected, amber led glows corresponding to that port.
Mallika
MallikaK_22
Hi Tetsuo,
Mallika
TeMa_2997106
Level 6
Level 6
Mallika-san,
Thank you for your comment. I will check it.
Tetsuo
