Hi..
When I compiled an FX3 example cyfxlowpowertest.c with EZ USB Suite,
an error occurred in final launch sequence. And this is the case when
trying the other examples.
Please tell me why and how to solve it. Thanks.
Jerry Lin
Failed to execute MI command:
-target-select remote localhost:3333
Error message from debugger back end:
localhost:3333: .s.u....¥¢±..A.].°.s.u...H...@.q......¥.¥..T.^...A...O.s.u..¥.¥¢±..A.].°.s.u..¥D.÷.L.k.^...C\r\n.
Most likely cause for this is the program puts the chip to low power. Once in low power, the JTAG commands cannot be accessed. This could cause such a message to come up.
I am assuming other programs are working correctly and only this one has a problem. Below are few forum threads which talk about loss of connection to a target device.
http://sourceforge.net/p/gnuarmeclipse/support-requests/48/
