I would like to test and verify the CY7C65630-56LTXC part before placing it on the final production board. A development board with a socket for the part would work great. If there is a socket that is also surface mount could be mounted on our board for a test fixture for us. Can anyone suggest a solution.
We have HX2LP DVKs, CY4605 and CY4606: https://www.infineon.com/cms/en/product/universal-serial-bus-usb-power-delivery-controller/hub-contr...
You can solder the silicon on these kits and verify the functionality.
Mallika
Mallika
Apologies for the delay in my response.
We do not have any other test-fixture or socket.
Mallika
