Dear Sir/Madam,
I have a custom board with CYUSB4347 (A silicon) on board.
Firmware update always failed.
End up found a way to complete update firmware by consecutive press the 'update' button without power cycle & USB cable detach on custom board after process complete with log file generated.
From log files, found there are different procedures between 1st & 2nd update, so I make an experience with a consecutive update firmware in 3 times.
Attach 3 log files in zip for analysis with the below questions.
Q1: From 1st log (dock_update_15_09_16_18.txt). Any hints to resolve the 'Unknow error: Did not get device removal notification'?
Q2: Compare 1st log (dock_update_19_09_16_18.txt) & 2nd log (dock_update_15_09_16_22.txt). Found there are missing Image#2 writing on 2nd update with complete status? Is it image#2 writing issue on 1st update?
Q3: Compare 2nd log (dock_update_15_09_16_22.txt) & 3rd log (dock_update_15_09_16_25.txt). The number of Images writing is the same (both skipping image#2), but the 3rd result becomes 'Complete Partially'. Is image#2 writing require? How to write it back?
Q4: From those log files, appear with 'Length mismatch in received message', will it affect the firmware update?
Below working environment & Firmware version.
EZ-USB HX3PD Configuration Utility (Version 1.0 Build 23) on Windows 10.
Firmware CYUSB4347-BZXC_FW_1_3_0.bin download from https://www.cypress.com/documentation/software-and-drivers/ez-usb-hx3pd-firmware
USB2.0 Type-A to Type-C cable between PC & CYUSB4347 Up Stream port.
Thanks for your support.
Ping
Hello Ping,
Could you please share the schematics if not confidential?
Mallika
Hi Mallika,
No problem, thanks for your support.
Do accept send through email?
Ping
Hi Mallika,
May I know is there any founding or suggestion?
Ping
