Dec 16, 2022
12:19 AM
Dec 16, 2022
12:19 AM
What is the voltage value for recognizing High or Low in the following signal, which is the data signal of CY7C65630-56LTXC?
D+
D-
DD+
DD-
My understanding is that these lines are differential signals, so the Vih/Vil given in the datasheet cannot be specified.
Tetsuo
Labels
USB Hosts Hubs Transceivers
03:56 AM
Dec 16, 2022
03:56 AM
Hi @TeMa_2997106,
Thank you for posting into our community.
The RX sensitivity is specified to be met with Template 4 in USB2.0 standard. Please find the following section in the USB2.0 standard.
>7.1.2.2 High-speed Signaling Eye Patterns and Rise and Fall Time
Dec 16, 2022
06:03 AM
Dec 16, 2022
06:03 AM
Takashi-san,
Thank you for your quick response.
I will check the specification.
Tetsuo
