Hi Sir,
We need Cypress USB-Serial Configuration Utility 2.0. to Configure VID & PID . please send me link where to download utility.
Before changing the default VID and PID of the device by using the Cypress USB Serial Configuration Utility, you need to change the INF and Catalog file to bind the device with the driver. Please confirm if you have modified the INF and Cat file.
Please download the USB-Serial Configuration Utility from USB-Serial SDK
could you send me example files. how to change INF and Cat file
Kulvinder Singh
Hi Kulvinder,
Please refer to this KBA: https://community.infineon.com/t5/Knowledge-Base-Articles/How-to-Change-the-default-VID-and-PID-of-t...
Also, the driver is only signed for default Cypress VID/PID. If you modify .inf to add your own VID/PID, the driver will become unsigned. To bind the device with modified driver, you can go for WHQL driver certification with your own VID/PID once your product is ready or you can opt for Driver Resell process provided by Infineon. Please refer to this KBA: https://community.infineon.com/t5/Knowledge-Base-Articles/Driver-resell-and-Driver-signing-FAQs-KBA2... for more details on Driver Signing.
