USB hosts hubs transceivers Forum Discussions
TeMa_2997106
Level 6
10 likes received 10 solutions authored 250 replies posted
Level 6
Can VBUSPOWER be directly connected to VCC (3.3V)?
I want to build in HX2LP inside the Host PC. Therefore, there is no VBUS on the system.
Tetsuo
Ajeethkumar
Moderator 10 likes given 100 replies posted 100 sign-ins
Hi Tetsuo-san,
Yes. As VIL for HX2LP is 2 to 5.25 volt, you can connect VBUSPOWER to VCC(3.3V) for your embedded hub application. I recommend you to connect VBUSPOWER to 3.3V via a 15K resistor.
Ajeeth
Ajeethkumar
Hi Tetsuo-san,
Ajeeth
TeMa_2997106
Level 6
Level 6
Ajeeth-san,
Why does it need resistor?
Ajeethkumar
Tetsuo-san,
It is a pull-up resistor(to limit the current drawn by the Microcontroller input pin) for the HX2LP input pin.
Ajeeth
TeMa_2997106
Level 6
Level 6
Ajeeth-san,
Thank you for your comment again. I could understand.
Tetsuo
