I use the CYUSB3304-68LTXI HUB USB in a project. I just need the HUB fonction and I don't need the power control modes. You can find the schematic attached at this post.
Note : all the decoupling capacitors isn't represented in this schematic.
Datasheet : https://www.infineon.com/dgdl/Infineon-CYUSB330x_CYUSB331x_CYUSB332x_HX3_USB_3.0_Hub-DataSheet-v21_0...
Thank you for your feedback !
Maurice.
Hi Maurice,
Thank you for posting in the Infineon Developer Community!
We have hardware design guidelines for HX3. It has a schematic checklist on Page 22. Kindly go through it and fill a Y/N against each item, post here.
Let me know if you have any queries in this.
Mallika
Hi Maurice,
Mallika
