USB hosts hubs transceivers Forum Discussions
YoIs_1298666
250 sign-ins 100 replies posted 100 sign-ins
Hello
We are trying H3X Blaster Plus to write the configuration data(Configuration A:Configure VID/PID and DID only) on EEPROM at CY4609.
but we can not connect I2C EEPROM(MODE SEL[1] = 0, MODE SEL[0] = 1 : I2C Master, read configuration from I2C EEPROM).
Why?
Yocchi
I will describe the basics and solution.
When we use CY4609, CY4609 USB 2.0 MTT Hub is connected as VID 04B4, PID 6503.
After CY4609 is configured on HX3 Blaster Plus, CY4609 USB 2.0 MTT Hub is recognized as PID 6502.
If we follow HX3 Kits User Guide, we can program EEPROM many times.
If you have any problem during binding driver to HX3, please try to following things.
1. Uninstall driver related to Cypress product.
2. Delete registry file of CYUSB3 and CYUSBHX3 in HKEY_LOCAL_MACHINE/SYSTEM/CurrentControlSet/Services/.
3. Delete CYUSB3.sys and CYUSBHX3.sys in C:\Windows\System32\driver as well.
Hirotaka Takayama
YangyangC_06
Have you binded HX3 to the correct vendor driver? That is, are you able to see the device which name likes Cypress HX3 vendor mode?
I saw the flowchart below.
But I can not find "USB2.0 MTT Hub".
And I can not find windows10 driver in \HX3 Blaster Plus\drivers folder.
What should I do?
Yocchi
1. Please attach the screenshot of your device manager when you connect HX3 to host.
2. You could choose either win7/win8/win81 drivers. It is ok for Win10.
Unfortunately, in Japanese.
Are you ok?
Yocchi
Obviously, your PC doesn't install the driver/HX3 doesn't enumerate correctly.
Please try to update your host driver.
I have two questions.
1. Of course I should connect between PC and HX3 with up stream port.
2. Where can I download driver?
    I instralled "HX3BlasterPlusSetup.exe".
Yocchi
Please find the driver according to your CPU vendor.
I take Intel as an example, for Intel user, one could download the chipset driver at Drivers & Software
Unfortunately, there is no change.
There is another information.
We can see "HX3 Vender mode" and write configuration data to EEPROM when the EEPROM is blank.
but once the EEPROM is written the configuration data, we can never find "HX3 Vender mode".
Yocchi
Hi Yocchi,
Your CY4609 Firmware might not be the latest version.
If you use an older version of the HX3 kit, with Rev *A silicon, you may upgrade to the firmware Version B3 available at http://www.cypress.com/?rID=92748.
The detail of the Firmware version is described on the Release Notes.
http://www.cypress.com/documentation/software-and-drivers/hx3-firmware
If you update latest version, I guess you can see both USB 3.0 and USB 2.0 Hub.
What kind of configuration data (or Firmware) did you write to EEPROM?
In case you want to change the PID value for USB 3.0 or USB 2.0 hubs, make sure not to assign any of the other standard PID values allocated for HX3 kits.
Hirotaka Takayama
Hello Takayama-san,
My HX3 Kit is HX3 REV *C SILICON.
>In case you want to change the PID value for USB 3.0 or USB 2.0 hubs, make sure not to assign any of the other standard PID >values allocated for HX3 kits.
  It is Configuration A:Configure VID/PID and DID only. All data are same as Internal ROM configuration.
No matter how I can not find "USB2.0 MTT Hub".
I will change this discussion from Community to Case.
Yocchi
Hi Yocchi,
You will see an USB 2.0 HUB and USB3.0 HUB if your host driver and HUB board work well. In your case, please
1. Use another HUB to see if it could enumerate well in your PC.
2. Try to switch the PMODE pins to internally ROM instead of external EEPROM to try with your PC.
3. If step 2 doesn't help, please try to connect your HUB to another PC.
4. Measure all the power domains to see if they are correct.
Unfortunately, I have only one kit. and I tried internally ROM and other PC.
I erase EEPROM data from external I2C master by setting MODE SEL[1:0] =[1, 0].
I can find "Cypress HX3 Vender Mode". but can not recognize driver.
but already installed the driver.
Hi Yocchi,
I checked it on Windows 10. Hubs name on Device Manager on Windows 10 is as follows.
USB 3.0 Hub: Generic SuperSpeed USB Hub
USB 2.0 MTT Hub: Generic USB Hub
I guess you have already known, but I showed it, just in case.
In your case, "汎用SuperSpeed USB ハブ" might be Generic SuperSpeed USB Hub and "汎用 USB ハブ" might be Generic USB Hub.
Hirotaka Takayama
Hirotaka Takayama
