USB hosts hubs transceivers Forum Discussions
AnIv_4752116
Hi All
I have a question regarding CYUSB3304-68LTXC, is there anyway to disable USB 2.0 functionality?
Looking at the datasheet I can only see a way to disable USB 3.0 functionality
Sananya_14
There is no direct option to disable the USB 2.0 part of the hub on the upstream port but you could disable the functionality on the individual downstream ports using the Blaster Plus utility. Please refer to the attached snippet.
You could also leave the USB 2.0 lines unconnected on the upstream port so that only the USB 3.0 part of the hub enumerates.
Sananya
Sananya_14
Sananya
Thanks for that!
