We use the CY7C65632-28 as a 3-port hub and we follow pretty close to the reference design. Issue is taht the chip keeps dying and I cannot figure what we did wrong to kill the chip.
Attached schematic, hope someone would show what we did wrong
Hello Lam,
I will check and update about the reflow temperature profile. Could you please probe the VCC and USB_nENP1 lines with no downstream devices connected? This will confirm if the power system is stable and it may be device dependent issue.
Sananya
-Could you kindly explain what happens when you say chip is dying? Could you kindly check the USB_nENP1 and RST#_USB signals at that instance?
-Please check if the crystal is working in that case. You can also check the KBA if it is similar to your issue.
Sananya
Hello Sananya,
Look like all vital pins are functional, 12 MHz clock, internal 3.3V are good, reset pin OK and I can see it toggles high-low-high on stimulus but USB_nENP1 stuck to high therefore no power to the client ports
Lam
Hello Lam,
Please check if any of the overcurrent pins OVRP1, OVRP2 or OVRP3 are asserted? Does the issue occur if you attach any other devices on the downstream ports?
Sananya
Hello Sananya,
There is no over-current happening. Even though it is a 4-port hub, we have only one downstream device permanently connected (ST Micro MCU). If we replace the part, the USB hub functionality would be OK for a while then the chip dies again. Do you know where I can get a reflow temperature profile for that chip?
Lam
Hello Lam,
Sananya
