        What USB termination resistor does CY7C64713 require? There is no hint in the spec.
 There is an internal pull up resistor .No need of extra pull up resistors on USB data lines.
Vikas
        I do not mean pull ups. But exernal Serial resistors in D+ and D- signals. Usually it should be between 20 - 30 Ohm. What value is recommended for CY7C64713 ?
prc_1505996
Level 4
Level 4
FX1 has internal series termination resistors in it.
