Dec 16, 2022
07:35 AM
Dec 16, 2022
07:35 AM
When powering up HX2VL, a waveform that looks like DP is slightly pulled up is observed.
Why is this happening? Is there any problem with this behavior according to the USB standard?
Tetsuo
Labels
USB Hosts Hubs Transceivers
09:38 PM
Dec 18, 2022
09:38 PM
Hi @TeMa_2997106 ,
Thank you for posting into our community.
Could you tell me which pin(D or DD) did you see the positive pulse at start up timing?
Also, could you tell me if you plan to use the device as bus power app no not?
There is internal 1.5k ohm pull-up resistor at DP, upstream line. It is pulled-up to 3.3V rail and ON/OFF by internal switch.
06:11 AM
Dec 26, 2022
06:11 AM
This waveform was observed at the DP pin (not DD pin).
Power mode is self-powered mode. Power is supplied from DCDC on the board. HX2VL is always ON when the system is ON.
Tetsuo
