USB hosts hubs transceivers Forum Discussions
VNM
We are designing a docking station which is capable of automatically disabling and enabling the ACA docking in runtime. Can you please suggest the circuit design for the same.
Ajeethkumar
250 replies posted 25 likes received 250 sign-ins
You can refer to the "Figure 5. ACA-Dock Support" of the HX3 datasheet for the block diagram of the ACA dock with HX3. Please note that you have to enable the ACA_DOCK configuration option.
You can also refer to CY4613 DVK schematics which supports ACA_DOCK functionality.
Ajeeth
Ajeethkumar
Ajeeth
Thank you for the suggestion but can be controlled by hardware?
Ajeethkumar
ACA_DOCK can also be configured through Pin-strap configuration.
For more details on the ACA-Dock feature, please refer to the "ACA-Dock Support" section of the HX3 datasheet.
Ajeeth
