ACA Dock (CYUSB3324-88LTXC)
VNM
We are designing a docking station which is capable of automatically disabling and enabling the ACA docking in runtime. Can you please suggest the circuit design for the same.
Ajeethkumar_P
50 likes received 500 replies posted 100 solutions authored
You can refer to the "Figure 5. ACA-Dock Support" of the HX3 datasheet for the block diagram of the ACA dock with HX3. Please note that you have to enable the ACA_DOCK configuration option.
You can also refer to CY4613 DVK schematics which supports ACA_DOCK functionality.
Ajeeth
Ajeethkumar_P
Ajeeth
Thank you for the suggestion but can be controlled by hardware?
Ajeethkumar_P
ACA_DOCK can also be configured through Pin-strap configuration.
For more details on the ACA-Dock feature, please refer to the "ACA-Dock Support" section of the HX3 datasheet.
Ajeeth
