Aug 19, 2021
02:33 AM
Aug 19, 2021
02:33 AM
Fx3 + lattice + two sensors (sc130gs) 130m (1280 * 1024), 200fps for each sensor. Is this scheme OK? Do you need to add a USB3.0 hub.
Cx3 each sensor uses 2 lanes, and each sensor can run 200fps
Labels
- cx3
02:48 AM
Aug 23, 2021
02:48 AM
Please let me know which part number are you using for your application. Is it CX3 or FX3?
CX3 can support maximum bandwidth of 2.4Gbps and FX3 can support maximum bandwidth of 3.2Gbps ( GPIF II interface). If you want frame rate of 200 than the video resolution and bits/pixel ( video format ) for both the sensors need to be adjusted such that the combined video throughput is less than the maximum supported by FX3/CX3
Rashi
Rashi
