some problems in CyU3PI2cSendCommand.help
who can give me some information about the CyU3PI2cSendCommand?
I read the Doc "FX3APIGuide",but i was confused about the CyU3PI2cSendCommand.
and
struct CyU3PI2cPreamble_t {
uint8_t buffer[8];
uint8_t length;
uint16_t ctrlMask;
how to use the buffer? how to use length? how to use ctrlMask?
Please look at cyu3i2c.h in C:\Cypress\FX3 SDK\firmware\u3p_firmware\inc, you should be able to find the necessary details through the comments in the file.
Anand
hi
    how configure CyU3PI2cPreamble_t if the register length longer then 8 bytes.
for example, if i want to read register address 0x123456789acbde1234,  the value with is 10byes, how to configure?
thanks
xingxing
