slave FIFO(Stream in) + Uart(FX3<->PC)
UnHa_3846631
Hi all,
I want to configure the board as follows.
FPGA <-> FX3 <-> PC (USB 3.1 Gen 1)
At this time, the interface between the FPGA and the FX3 is conceived as a stream in method of the slave FIFO.
The main function is to transfer video data to PC, but I want to use UART communication together.
In case of not transmitting video data, UART communication between PC, FX3 and FPGA is tried to send and receive commands.
If you can, please let me know if you can configure the board in this way.
SrinathS_16
Please refer to the project attached in the below thread.
Can EZ-USB FX3 enumerate serial devices and video and video devices at the same time?
Srinath S
