ScGr_289066
100 replies posted 50 replies posted 25 replies posted
I see in the FX3 TRM that the CX3 has weak internal pullups, but there's no API (that I found) to enable them.  How is this done?
Scott
HirotakaT_91
500 replies posted 250 replies posted 100 replies posted
You can set registers or use FX3 SDK API CyU3PGpioSetIoMode to set pull-up or pull-down on an I/O pin.
Please refer to the FX3 datasheet and TRM 4.1.3 GPIO Pull-up and Pull-down.
https://www.cypress.com/documentation/technical-reference-manuals/ez-usb-fx3-technical-reference-man...
Hirotaka
HirotakaT_91
Hirotaka
Hi Hirotaka,
Perfect, just what I needed.
Scott
