I have designed a camera board usb cyusb3014,it can download and work correctly under usb2.0,but can not work under usb3.0,or it can not connect to the host computer。I have looked up some same cases via the internet but there is not a solution,i think it is not a hardware problem。expect your reply!!!
USB Superspeed Peripherals
- cyusb3014
Could you share with us your schematics file and your firmware project?
AliAsgar
here is the SCH
hi,is there any suggestion?😐
frimwares used from SDK1_3_4,none of them worked as usb3。we had some print information of the connect of usb below.
i need your help.
1. Could you try programming UsbBulkSrcSink firmware to the FX3 and share with us the USB debug logs.
2. Is Type C receptacle being used or Type B?
3. USB traces are long and thin and are not to be protected by GND.
4. Please refer to the KBA on enumeration issue : https://community.cypress.com/t5/Knowledge-Base-Articles/Trouble-Shooting-Guide-for-the-FX3-FX3S-CX3....
5. Please try the same setup with different hosts and let us know if the problem persists.
AliAsgar
😀THANK YOU! Type C receptacle is not used,it is actually the reason for usb3.0 not being connected.i suggesst putting it in the hardware design guide.
I couldn't quite understand what you meant. Could you please make it more clear.
AliAsgar
😅 .i mean i use the type c connector but not use a Multiplexer。
Was a Type C receptacle used without a multiplexer? Because of which USB 3 was not getting connected on one side.
AliAsgar
YES it is.
