Without camera interface, Hard coded RGB or yuy2 data has to be streamed to host using fx3
I am using fx3 development board, presently i dont have camera module but before that i want to hard code 12 bit rgb data and want to stream to host using fx3 board.
Is there any example code for that
alamandaa_16
10 likes received First like received
Hello CHETHAN SK,
-Please go through the below-attached source file, which speaks about 640X480 resolution,16 bits per pixel and hard-coded yuy2 data format.
The attached example firmware works USB 3.0, USB Full Speed and USB Hi-Speed.
Anil Srinivas.
alamandaa_16
Hello CHETHAN SK,
Anil Srinivas.
Thank you for your reply,
but i did not find any attachment to your previous email
