Add start state RD_START and GPIF II compile passed.
Change SRAM_READ_COMMAND, CyU3PGpifSMWitch toState to 'RD_START'.
Why tool still reports 'RD_START' can't be resolved?
- initial state
- Please ensure that the cyfxgpif2config.h file is getting updated after you build it from the GPIF II designer.
- From your project, I could find that there are two cyfxgpif2config.h files. The cyfxsrammaster.c file has the include statement that identifies the cyfxgpif2config.h file in its own directory. But, the GPIF II designer generates the cyfxgpif2config.h file in img_cpif.cydsn folder. Please modify the Build settings in the GPIF II designer to point to the same directory as cyfxsrammaster.c file.
Srinath S
