09:27 AM
May 25, 2017
09:27 AM
I'm designing a stereo UVC device with the CYUSB3014 FX3 and two AS0260 CMOS sensors. I took the AN75779 as reference design, which allows to interface one MT9M114 with YUY2 output format directly to the GPIF-II port of the FX3. The AS0260 is actually similar to the MT9M114, but with higher resolution. It outputs in JPEG format, providing higher performances in terms of fps (thanks to the compression).
I'm wondering if it is possible to use the reference firmware to make it work with JPEG format.
JPEG has variable LV (line valid), that's my only concern. I'm afraid that the state machine can stuck.
Labels
