I am trying to use UVC and UAC composite device in CX3. The UAC device in Windows 10 report error whereas UVC device got driver installed. If I make it as standalone UAC device, it works fine (device driver got installed).
Can you give me descriptor file for UVC and UAC composite device for either high speed or super speed?
Please try the attached descriptors for a UVC + UAC (Mic + Speaker) device. This descriptor file is created by modifying the descriptors of the SDK example project cycx3_uvc_ov5640 found in the following location:
C:\Program Files (x86)\Cypress\EZ-USB FX3 SDK\1.3\firmware\cx3_examples
The modifications are made only for super speed configuration descriptors. This can be used as a reference to modify other descriptors. The functionalities and other fields within the descriptors can be modified as needed.
Jayakrishna
