USB Superspeed Peripherals
hi,i install the EZ-USB FX3 SDK 1.3 and there two host application examples,bulkloop and streamer,i build the streamer example with VS2008 successful,but bulkloop unsuccessful,how can i build this example successful,use vc++6.0 or VS 2008,I  need your help ,thanks!
Hi VS 2008 is used to build. If you used the original bulkloop application on the SDK, is it working?
Hi,the original bulkloop application on the SDK does not work well,i rewrite the application with VS 2008 MFC.Now it is well. Thanks!
