Commonly if you want to redebug a board with JTAG connected, what ever the status the board is, you just end the current debug and begin the new debug session.
According to the documents, now if you want to redebug CYUSB3KIT-003 like debug a modified version, then you need to :
(1)End debug
(2)End gdb and OpenOCD
(3)Reset the board by press the reset button
(4)Redebug
This is very complex.
Is there easier way?
ispn:38621:1:0
l1:314:1:0
Please go through the following link: Eclipse and JTAG debugging: Run / Debug buttons
Please read the last interaction which gives a possible way to do what you want to implement.
Yashwant
Can you elaborate what you meant by "modified version"?
Do you mean, changing the firmware and rebuilding the firmware image?
Or just using the existing firmware image and restarting the debug session again?
Yashwant
Both - anything that is common during debug.
Yashwant
It says "Error stopping at main Reason:target request failed:failed to interrupt"
Apologies for the delay.
Can you please share a snapshot of the error message?
Can you please tell what you exactly did when you see the error?
Yashwant
