USB Superspeed Peripherals
NaMo_1534561
Contributor II
Is there a recommended power supply circuit diagram when using fx3S with self power?
Please tell me about the processing of the VBUS and VBATT terminals.
Naoaki Morimoto
HirotakaT_91
Hi Morimoto-san,
Thank you for sharing detailed information.
Your suggestion seems good except VBATT setting.
In case of the VBATT usage, CYUSB3KIT-001 schematic might be helpful.
On your suggested power supply, FX3 is not supplied any power when USB (VBUS) is not connected to it.
In case of self-powered device, VBATT can use for resolving above issue.
Following graphics are excerpts of CYUSB3KIT-001 schematic.
Hirotaka Takayama
